03-04-2012 06:33 AM
how do I find the build application? I have used Labview when 6.1 was out and then none for many years. I am just starting again because I to develop system controls and GUI etc needs. I have the Labview 8.5 pro on Win 7 pro with 32 bit XP virtual machine installed. I can develop control GUI's on Labview and work it etc etc. But, the Build appplication can't be found, I need to build stand alone .exe for running on other machines within lab from my development PC. I am attaching a .jpg for you to look at. Any one can help, I will appreciated it Thanks.
03-04-2012
07:13 AM
- last edited on
01-21-2025
05:55 PM
by
Content Cleaner
For creating an installer for your application, you need to build an project for the same.
Follow this link for it : http://zone.ni.com/reference/en-XX/help/371361E-01/lvhowto/building_a_stand_alone_app/
03-04-2012 08:21 AM
Puneet, Thanks for your swift reply. I am not quite follow. I have looked at that same link after, I have posted the question. As you can see on my attached .jpg on the earlier post, I can see the build, build all, run from the Project tab. But, none of them are 'active' no highlighted, its seems I need to activate something?!
you say; for creating an installer for my application, I need to build an project for the same. Can you elebrate on that please? I thought I saved it as a .VI, do you mean, I should save my project as something else?
The NI link talks of look from the 'project explorer' and/or 'my computer', I don't sems to able to find through either omne of them.
I would most appricate if you can help further, or anyone else can for that matter.
Vis
03-04-2012 09:24 AM
Things have changed considereably since 6.1.To creat an exe, you have to first create a project. As your image shows, select New Project. You can add your existing VI to the project. Refer to the help for details on the project ag and building applications.
03-04-2012
11:27 AM
- last edited on
01-21-2025
05:51 PM
by
Content Cleaner
Open LabVIEW >>> Create Empty Project >>> Add folder or files in the project using this link https://www.ni.com/docs/en-US/bundle/labview/page/managing-a-project-in-labview.html.
Save project and then use previous link for builing an executable for the application.
03-04-2012 11:54 AM
03-04-2012 12:22 PM
Great to hear this.
