labview 8.5 /generatespecfile not working
i am trying to make a silent install for labVIEW 8.5 however whenever i use the /generatespecfile parameter on the setup exe a pop up comes up saying Invalid command line parameters. any help on this matter is helpful.
(3,320 Views)
any help at all is helpful
(3,310 Views)
Have you read through this doc?
http://ae.natinst.com/public.nsf/webPreview/C361087EE9F20810862577850073128E?OpenDocument
Kareem W.
Web Product Manager
(3,294 Views)
is the link you posted correct? i cant seem to open the page
(3,286 Views)
The link worked when I just clicked on it. You can also search "5CJFIUGL" from NI.com. This is the document ID.
Kareem W.
Web Product Manager
(3,281 Views)
i have read through that documnet and it still wont work. here is the code i am using
cd T:\virtual_dvd_location
setup /generatespecfile k:\labview_specfile.txt
(3,264 Views)
I don't see anything wrong with your syntax. The only thing that I can think of is that there may be a hiccup in trying to reference files on a virtual optical drive. You can determine if this is the issue by moving the files to the c: drive and trying this process again.
Kareem W.
Web Product Manager
(3,245 Views)
