labview 8.5 to labview 7.0
i am on my labview working with 8.5
but at work, we only have labview 7.0.
what would be my best way to get my vi to be 7.0?
thank you so much
Message Edited by krispiekream on 06-19-2008 03:59 PM
Krispiekream
Message 1 of 10
(3,948 Views)
In order to go from LV 8.5 to LV 7, you will need to have LV 8.5 (save it back to 8.0), LV 8.0 (save it back to 7.1) and LV 7.1 (to save back to 7.0).
If it's only a few small VI's, you can post them on the forum and ask someone to do the saves for you.  (Best if you do the save back to 8.0 and post that in order to eliminate 1 of the 3 steps for whoever will do the rest of the conversions for you.)
Message 2 of 10
(3,932 Views)
yeah. great..
i did all those steps.
i went from 8.0 to 7.1
i dont have labview 7.1 so i can't go to 7.0.
can someone please help me.
Krispiekream
Message 3 of 10
(3,913 Views)
Hey Krispiekream,
Please try the attached to see if it works with LV7.0
Hopefully it does!!
Aashish M
CEO
TransferFi
www.transferfi.com
Message 4 of 10
(3,875 Views)
thank you so much.
i'll try it right now.
Krispiekream
Message 5 of 10
(3,871 Views)
hi there,
i somewhat got it to work.
but i am having this error everytime i try to save it.
does anyone know how i can get rid of it?
Message Edited by krispiekream on 06-24-2008 06:02 PM
Krispiekream
Message 6 of 10
(3,850 Views)
You might want to look into What Does an "Insane Object" Error Mean and What Should I Do?
Hopefully this helps!!
Aashish M
CEO
TransferFi
www.transferfi.com
Message 7 of 10
(3,834 Views)
Can somebody save the below VIs in LV 8.0 for LV 7.0/7.1, please... ?! Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 8 of 10
(3,817 Views)
It is very urgent. Can somebody please do it asap... ?
Message 9 of 10
(3,811 Views)
In the attached VIs in my prev post, what I m trying to do is, find the 0 in the 0th column of the 2D str array (Citadel), at which index, the value in the 1st column of that array should be equal to its prev index's value.
When the above conditions are True, the corresponding index's value in the 1D Timestamps array will give me the correct timestamp of the instance of Power Interrupt Time.
Again, I ve to repeat this process to find out all the Timestamps of Power Interruption.
Now, I also have to find out the Time of Power Recovery, which is the exact reverse process of this.
I ve to search the 0th column of the Citadel 2D array after a series of 0s & take the first non-zero value's index after every series of 0s, & index the corresponding value in the Timestamp 1D array to get the Power Recovery Time.
I ve done the first part & terribly stuck up in  the latter part of the logic in finding out the Power Recovery Time. Smiley Sad
Can somebody help me in bailing out of this situation?
Message 10 of 10
(3,807 Views)
