labview 8.5 vi wont communicate with Max . no error
I replaced my hard drive , now my VI wont communicate with Max. Windows xp. My app was working now it wont work . If I run a task or test panel in Max I am able to communicate to my devices , should  i Re-instal Daqmx ? LABVIEW 8.5
(3,571 Views)
What version of MAX are you using?
(3,564 Views)
not sure I will have to check . The app was working prior to me replacing the hard drive . I made a ghost image and installed a new hard drive . Max acted a bit goofy and changed all the device numbers , for example DIV1-4 became DIV5-8 . I changed them back to the original. All my  digital and analog read / writes work from using the test panels and from a task for each signal type all work perfect in max. My VI hasnt changed . Also it says my Labview licence has expired so I changed the date backward . We have a corporate licence and this computer is XP so its not on the LAN.
(3,562 Views)
