11-26-2008 01:00 AM - edited 11-26-2008 01:09 AM
In my computer ,there are saveral sound cards.These cards is added in the computer except the first one. I can know the number of each card.When I want the sound from one of the card,I need put the number of the card to the ID Drivce of sound output configure.The question is that if I put the number of 0 to the ID Drivce of sound output configure,the first card can be used.But,when I put the else number of the card to the ID Drivce of sound output configure,no card can be used,why?Thank you very much!
11-27-2008 11:28 AM
Hi Fairypan,
Thanks for the post and I hope your well.
Im not sure I understand your issue - could you maybe post your LabVIEW code?
If you could try to rexplain the issue, maybe with a screenshot - this would really help!
I would make sure you have configured for your system for multiple soundcards. Maybe see this link (external).
Kind Regards,
James.
