labview 8 trouble with table properties
I wrote Program with Labview 7.0 then I change to Labview 8 but it look like the table Properties is different ,In labview 7 I can set up each table's cell blinking,but labview 8 cann't.who can help me?
(3,222 Views)
Could you post the code that you had working in 7? That way I can take a look to see what you are trying to do. Thanks!!
Tyler H.
(3,210 Views)
I think they are refering to using a table property node using Active Cell->Blinking and getting individual cells to blink (See attached).  In LV8, the same operation causes the full table to blink.
I don't know if there's a fix, other than manually controlling the blinking through the BGColor property (See attached)
2006 Ultimate LabVIEW G-eek.
(3,199 Views)
yes your think is right.
in labview 7 I can set up Active cell individual blink.but same properties note don't work in labview 8.
(3,182 Views)
I can fix it ,but I have to rewrite my program!
(3,181 Views)
thank you for your help!
(3,178 Views)
