labview 8 vista
hi,
 I have labview 8 student edition which i have been using with windows XP, now i bought a new laptop with windows vista 32 bit and when i tried to install the labview 8 student edition it crashed my system and now everytime i reboot vista it says labview stopped and windows will contact you if they resolve the problem.
how can i install my labview? what drivers do i need?
any help will be appreciated
thanks
Message 1 of 8
(5,338 Views)
labview has recently released it's version for vista OS. try that..
Message 2 of 8
(5,330 Views)
Hi Pal1977!
At the moment the only versión of labview supported under Vista OS is 8.2.1.
Thats the reason why labview 8.0 is not working. You can try to download a trial version of 8.2.1 here.
Best regards and have a great day! 🙂
Oswald Branford
Message 3 of 8
(5,325 Views)
that is so crap. i am a student i cannot afford to buy new ones. i wish the labview 8 worked with vista, i guess i will uninstall windows vista and install old windows xp in my laptop
Message 4 of 8
(5,309 Views)
If you are a student, it may be worth checking whether your school has a volume license agreement with National Instruments so that you have a reduced cost or even free option for getting access to LabVIEW 8.2.1
Kind regards,
-Sam F, DAQ Marketing Manager
Message 5 of 8
(5,274 Views)
i had already checked with my college license , they do not have it , why else would i be using the student edition?its not fair on windows and other software companies to force to buy new edition, they should have been backward compatable.
Message 6 of 8
(5,254 Views)
It's a bummer to install a program and find it doesn't work with the operating system. But. Incompatibilities with a new operating system are just business as usual. Happened with XP. Happened with 98. Etc.
There's a good reason people are not in a hurry to upgrade. There's a reason Dell still sells XP on professional-type machines. There's a reason they call it "bleeding edge."
Message 7 of 8
(5,214 Views)
Hi pal1977,
Please also bear in mind that LabVIEW 8.0 was released in 2005, long before the release of Windows Vista.  There is really no way that LabVIEW could have been designed to work on an operating system that did not yet exist at that time.  On the other hand, I have seen older versions of LabVIEW work on Vista, but there is no guarantee that versions earlier than 8.2.1 will work.
Unfortunately, your options are to either revert back to Windows XP or upgrade to LabVEW 8.2.1 in order to be sure that your setup will work.  I realize this isn't ideal, but please note that the student edition of LabVIEW is very affordable.
Chris M
Message 8 of 8
(5,159 Views)
