labview 9 can not open examples of Labview 5
I had found some VI of keithley 2400, but those Vi are written by labview 5, and my labview 2009 can not open these examples. I do need some examples to learn how to control keithley 2400. Hope someone will help me. thank you so much.
(3,163 Views)
The driver is in version 8 and loads quite nicely with 2009.
(3,157 Views)
You can usually just post the VIs in question and someone can try to save them in a newer version so you can open it. Have you looked in the Instrument Driver Network for updated drivers?
(3,154 Views)
thank you, I found the new version and opened it. can i ask one more qestion? if i want to use the keithley 2400 to measure voltage and Current graph of a resistance, the download driver can be used directly? sorry, i am totally a freshman.
(3,144 Views)
You can do that. There's a configuration VI to configure the measurement. I don't recall if the 2400 is capable of dual measurements. If not then you would need to first configure it to measure voltage, take a reading, then configure it for current, and take that reading. These operations would be in a loop.
(3,112 Views)
