labview- .EXE file with excel template
Hi saamy,
Oh. I mistake. I am sending it now. Please take a look and let me know.
Steve
Message 11 of 15
(920 Views)
Thanks a lot Steve, Sure I will let u know once am done.
Message 12 of 15
(904 Views)
Hello Steve,
I am facing a problem When I try to build .vi file inorder to create .EXE file. Its showing Build error like "Shell32.dll"error. I have attached the screenshot of that error message as image file. Plz chk that and let me know if you know the solution.
[my labview version is 10.0 (Labview 2010)]
Thanks in advance
saamy
Message 13 of 15
(894 Views)
Hi Sammy,
Pls check there is the file (...\windows\system32\shell32.dll)?
If no, you may need to download the file from some other sources.  If yes, pls check whether you are able to copy the file to some other folder?
If the file is there and are able to be copied, we shall try to look more deep into the problem.
Steve
Message 14 of 15
(886 Views)
Yes Steve, that file is present in that path and I can able to copy that file and put it in another folder.
Message 15 of 15
(883 Views)
