labview .NET Interop Assemblies 1D Array
when i use labview build a .NET Interop Assemblies and try to invoke with vs2015 c#,it appears labview 1D array  Cannot convert from double [] to double [*]
labview 1d Array have a “*“ in bracket,but 2D Array works well
(1,391 Views)
Accepted by topic author 恕_Godspeed
it seems lv problem  , before is lv2017 f2  after lv 2017 (sp1 f4  2018sp1 f4 )then  the 1D Array datatype is normal
(1,318 Views)
