labview and code composer studio3.1 compatibility
hello!!
i m currently working on cc3.1.i want to know that which version of labview is exactly compatible with cc3.1?coz i m having error while i use matlab because ccs3.1 support matlab 7.2 or 7.3 version.
(3,044 Views)
Hello 0223,
I looked through some of our older documentation because I was not familiar with the products you were describing. I looked in the LabVIEW DSP Test Integration Toolkit for TI DSP manual. I looked at page 2 of the manual and the requirements are listed as follows:
LabVIEW 7.0
CCS IDE 2.2 or later
TI DSP development platform that you can configure with CCS.
The C2000™ DSP platform is compatible only with the toolkit
automation VIs.
It looks like if you are using this toolkit you can only use LabVIEW 7.0.
Note: This product is no longer supported by National Instruments.
Jon S.
LabVIEW NXG Product Owner
(3,030 Views)
