I just used Motion Control to generate code for LabView. First of all, will this code run as-is? I'm thinking that Labview needs to know what instrument I am wanting it to use. MAX and Motion Control had no problem finding the instrument but Labview doesn't have it in its instrument lists. So I tried to find a driver on the instrument driver network with no luck. Before I make a request for a driver I wanted to find out how much of what I'm doing is correct. Thank you in advance.
-Nichole
