labview and ole-server
I need information about the activation of an "OLE server" via Labview.
This server is activated without any problems by using the "CreateObject ("servername")" command within the Excel and Visual Basic environment and all methods are available. I tried an automation-refnum to find the server in the Labview Library - without any success.
How might I realise this Labview Problem?
Alex
(3,709 Views)
Hi BSS
OLE is only renamed to ActiveX by Microsoft.
So you can communicate with the "OLE server" over ActiveX.
for more information see the following link
-> http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnaxctrl/html/msdn_actxcont.asp
You can find a lot of examples about ActiveX communication in the LV library.
Lars
(3,684 Views)
Hi Lars,
thank you for your answer, but i do not see the registration in the type library.
How do i get this information?
Alex
(3,673 Views)
Hi BSS
Your ActiveX device must be registerd in windows.
Than you can create for example an ActiveX Container.
Open the context menu by right-clicking and  select "Insert ActiveX Object ..."
Is your ActiveX device not listed there. Choose "Create Object from File"
instead of "Create Control"
and directly select it
I give you some attachements to visual the actions.
Lars
(3,667 Views)
