labview and parallel port
I have installed Labview 2010 32 bit in windows xp, but i cannot find "deviceand interface"  in measurement and automation
can anyone help in this regards.
Do i need driver to access parallel port in labview?
thank you
(2,720 Views)
It's right under Data Neighborhood in My System.  Click the + next to My System to open the choices under it.  It should be very easy to find unless your MAX has a big problem.
No, you don't need drivers to communicate with the parallel port.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,704 Views)
