labview and siemens plc
Has anyone experiences using labview and a siemens simatic S7-300 plc. I
have to communicate with the plc and want to write an read values
directly via ehternet from labview. I would prefer ehternet because
profibus cards are much more expensive. Maybe someone could give me a
link or example code fo that solution.
best regards,
Max
(4,048 Views)
Hi Markus,
one of my customer is using OPC server to talk to a S7. This was a larger project and the S7 part was the one he was doing.
There is a S7 OPC-Server available from deltalogic. They have a LabVIEW library and a demo version.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(4,048 Views)
waldemar.hersacher wrote:
> Hi Markus,
> href="www.deltalogic.de">deltalogic
> and a demo version.
> Waldemar
That sounds good!
A direct access to the plc registers would be the easiest way and sould
cause no problems. I just whant to know if i need a special Ethernet
connection (Industrial Ethernet) or if i can thake a standart Ethernet
card for the PC. Is the Hardware different or do they just use another
protocol?
Max
(4,048 Views)
Hi Max,
you need a normal ethernet card in the PC, in the S7-300 it's a CP 343-1 in the S7-400 a CP 443-1.
I don't know which port is used for the communication. If you have a personal fire wall running on your local machine or between your machine and the S7 the connection may not be successfull.
Waldemar
Waldemar
(4,048 Views)
