labview and thermo scientific instrument
Hi, we have thermo scientific mass spec (prima db) i want to communicate to it through its opc server. Currently it will not install the software correctly, anyone come across this??
Stu
(3,627 Views)
Hi Stu,
I've got a few questions about this problem. Is the OPC server from National Instruments? What is the problem with installing the software? (error codes etc)
I hope we can get this problem sorted out for you soon.
Message Edited by Owen.S on 09-29-2009 05:19 AM
Owen.S
(3,604 Views)
Hi, no its the thermo scientific own opc server and you have manually configure the dcom settings. The problem i have when install the opc server software, it does not add the the server to the dcom folder within the components directory. any other software like fieldpoint or eurotherm does this automatically. And then you can view the entry within this dcom folder.
Stu
(3,585 Views)
Hi Stu,
I'm sorry but we cannot support software that isn't our own. You will have to contact the manufacturer and ask them, or hope someone see's this post and knows something about your problem.
Again, sorry I couldn't be of more help but I hope you understand.
Owen.S
(3,564 Views)
