labview arduino programming
how can i command a digitalWrite input to toggle between two states true and false and pause in the false state, i thought of using wait but i don't know how to do it? can you provide a sample program please
(1,762 Views)
Hi Sarhila,
You need to wire your TRUE/FALSE value to the DigWrite function, changing between states!
Place a Wait function in the FALSE state!
To sum up: in a statemachine your questions are easily to solve, all you need to do is to program the proper actions in each state…
(1,752 Views)
I am a beginner in labview programming for this I find difficulties. as you see in the picture i control three digitalPin at a time but i need to switch between two states only digitalPin 2 (valve), so can you suggest an example program please.
(1,738 Views)
It is not polite to show plagiarized code without giving a link or context.
You simply need another state (call it "wait"!) and switch to it depending on needs.
(1,686 Views)
