labview consuming cpu with no running vi
I'm running Labview 2012 12.0f3  64 bit Professional.
When my laptop comes out of standby, Labview starts consuming 13% CPU with no running vi's.
There are several VI's open but not running.
This is very annoying.
Is this expected behaviour or a known problem?
(2,537 Views)
(2,499 Views)
Thanks!
It does seem to be the same issue maybe with a bit of a different symptom.
Instead of one CPU at ~100%, I have 4 CPUs each at 13%.
Still, this is enough of a load to make a noticeable difference to the performance of my workstation.
I hope it gets fix in the next patch.
(2,466 Views)
