labview crashes every time I click on a broken arrow (vi has errors).
I just upgraded Labview from 7 to 8.5.1 a few weeks ago.  Now, when I press the broken arrow to check the errors in a vi, Labview crashes.  This is a vi that was developed using the state diagram toolbox under Labview 7.  I now have the state chart toolbox but not the state diagram toolbox.
(2,535 Views)
Try to disconnect the state diagram from the the state diagram (right-click on the main while loop).
If that doesn't work in 8.5, try to do this in 7.1.
Or install the state diagram toolkit in 8.5.
Ton
My LabVIEW Ideas
(2,530 Views)
Hi Randy,
I would install the the State diagram toolkit for LabView 8.5. However, be sure to uninstall your earlier version of the toolkit before doing so.
Ipshita C.
(2,497 Views)
I think that may be the problem; there is no state diagram toolbox anymore now there is the state chart toolbox which is different.  I went back and unlinked my code from the state diagram toolbox and this did not help the problem but thanks for the suggestion.  Yesterday I submitted my code to NI to see if they can reproduce the problem.
Randy
(2,485 Views)
