labview crashing when calling labview-built dll
Looks like we had the same problem with calling a DLL in LV.
Mine was related to a string output of the DLL.
Initialise you string output with a string of 412 characters and you're fine.
Strings can be intialised in the following way:
Message Edited by andre.buurman@carya on 05-26-2008 10:58 AM
André (CLA, CLED)
Message 11 of 14
(598 Views)
Thank you so so so very much sir!!
We had been worrying over this for a week!!
As of now its running fine, without crashing!!
Smiley Happy
Thanks again!!
Message 12 of 14
(593 Views)
MScap wrote: Sir, I have made sure that the strings are defined with a minimum length. The array size is connected to an other input(no of steps). As i said earlier, the vi runs fine, without crashing, when all the input parameters are passed. If i do not pass even one parameter, i should get an error message (of max 412 characters). I get this error message and then LV crashes.
It's extremely hard to understand what you are exactly doing. Not passing parameters seems like a defnitive error to me but I might misunderstand what you are doing. Showing your code both how it works and how you try it when it doesn't work would definitly help a lot. Putting up the actual VI with an example of what you try to do would be best.
MScap wrote: Thank you so so so very much sir!! We had been worrying over this for a week!! As of now its running fine, without crashing!!
Well I see you got it solved. What I told you in my previous post was in fact the same as what Andre told you later on in a different way.
Rolf Kalbermatter
Message Edited by rolfk on 05-26-2008 12:32 PM
Rolf Kalbermatter  My Blog
Message 13 of 14
(589 Views)
Well!
I will not be able to post the actual code.
I tried with empty parameters because, this DLL will be used in VC++ by someone else.
i wanted to make sure that, if the user passes empty paramters, by mistake, the function returns an error. That was the reason, i wanted my vi to run with empty paramters and return the error message.!!
anyways!!
Thank you both of you for spending your time on my problem!!
Message 14 of 14
(582 Views)
