labview data collection and storage?
for a complete labview beginner, what is the best way to collect data from hardware connected by rs-422 serial port?
Message 1 of 23
(8,490 Views)
Not with hands. Smiley Very Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 23
(8,480 Views)
If you have NI VISA installed, you should have the Instrument IO Assistant. This is a configurative tool for communication with VISA instruments. RS 422 is a serial interface and therefor can be accessed by VISA.
Please read more about this starting with this webpage
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 3 of 23
(8,476 Views)
For a complete beginer I will suggest trying the communication with hyper terminal.
Message 4 of 23
(8,465 Views)
here are some links to the serial loopback within LabVIEW.
http://zone.ni.com/devzone/cda/tut/p/id/3450#toc2
What technics have you tried of attempted to use?
are you sure it is a RS-422 connection?
what information have you already gather on the topic?
Regards
Jordan Power
Message 5 of 23
(8,389 Views)
I have tried to use the I/O assistant, and I think it is able to read. What is the easiest way to plot this input against time it was read on a graph or in a table if that is easier?
Cheers
Message 6 of 23
(8,354 Views)
Message 7 of 23
(8,338 Views)
does anyone know if u can write to a csv file on labVIEW? basically want to a produce a spreadsheet with serial input values and time?
Message 8 of 23
(8,325 Views)
See here
But start a new thread...........................
Message 9 of 23
(8,322 Views)
At the moment i've set up the attached but I can only get it to input one set of values. how can I get it to continuosly output the files? Secondly I would rather out put them to a spreadsheet format, with the five different numbers (three from I/O assistant and two from Date/Time String) in diferent columns? Im trying to use the write spreadsheet VI but it needs an orange connection?
Cheers
Message 10 of 23
(8,288 Views)
