labview data storage
How can I storage a Data without it appears in the front panel....for example: if I add 4+5 = 9 this "9" how can I storage in a data base.....
(2,653 Views)
I don't completely understand what you're asking. Are you trying to save data for later use in your program, or are you trying to save data to a database? For a database, have you done a search? If you had you would see that there are many posts on this, and there are numerous suggestions. Please explain what you're trying to do better. Does this have anything to do with the other posts you created which also have very little information?
(2,629 Views)
