labview drivers for Prisma QMS
Hi Stoad,
Finally I could read the OPC data! The problem seems to be permissions. I was receiving errors on all OPC clients, something like "access denied 0x80070005". I was running the aplications as normal user (Im supposed to be admin on win10 but I dont know...) and realised that if you run the aplications (Matrikon and LabView) as administrator (right-click->run as administrator) there is no problem retrieving data.
Im writing this just to thank for your help, couldnt be possible without it.
Have a good time on the other side of the world!
Message 61 of 95
(2,747 Views)
Hello Gernot,
I have recently faced the issue of controlling QME 200 (via RS-232) from the LabView environment. I would be very grateful for any help, especially including VIs.
Thanks in advance,
Witek Piskorz
Message 62 of 95
(2,683 Views)
Dear Witek
Here I have attached a few Vis to help you to communicate with the QMG200.
These are only fundamental Vis.
Hope they help you to get a step forward.
Gernot Hanel
IONICON Analytik Gesellschaft m.b.H.
Message 63 of 95
(2,666 Views)
@nottilie wrote:
Dear Witek
Interesting! Is it possible to get the checksum VI?
Message 64 of 95
(2,663 Views)
The checksum is calculated here
Gernot Hanel
Message 65 of 95
(2,660 Views)
Alles klar! 🙂
Message 66 of 95
(2,658 Views)
Thank you so much! You have saved me a lot of time 🙂
Witek
Message 67 of 95
(2,650 Views)
You are welcome
Gernot Hanel
Message 68 of 95
(2,648 Views)
HI ,
Gernot
i have same problem and i have Quadera software but the picture you share for OPC server in Quadera i couldnt found it. looking forward for your positive answer.
Taufeey
Message 69 of 95
(2,554 Views)
Dear Taufeey
I am really sorry but I cannot find out what your question is.
This tread has many different topics.
It started only with the serial communication of Pfeiffer Prisma and the went to the OPC communication of Prisma+.
So please explain your problem clearly so we can "hopefully" help you if we have an answer.
Cheers
Gernot
Gernot Hanel
Message 70 of 95
(2,550 Views)
