labview dsc
Perhaps it's a simple question. But I've just begun using labview...
I have a project in which there a library named mymodbus.lvlib. In the lvlib file I've declared a I/O server (modbus master) with 3 shared variable. Also I've enabled logging for all 3 variable and in the properties of mymodbus.lvlib->DCS Settings : Database, I've enabled  Data Logging and my database path is C:\Program Files (x86)\National Instruments\LabVIEW 2011\data.
In my development enviroment, my project works well. But, I could'nt make an installer or an executable that run on target PC which has not Labview installed. My question is how should I define the Citadel database and My library that finally works on target PC.
I've attached screenshots of:
  •  Project Explorer
  • modbus.lvlib properties
  • vi file
Any help whould be appreciated.
(4,970 Views)
  •  Project Explorer
  • vi file
Problem during building Installer or making the installer to work in Target PC
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,954 Views)
I want an application that runs on target PC. Suppose that my target PC runs a fresh windows and have not labview installed.
Actually my executable file runs on my develoment PC and I do not have problem with it. All I want to know is how to run the application on target PC.
(4,951 Views)
Make sure You are Adding all the Tool kit and Third party Drivers and Necessary Library Files along with Additional Installers, While Creating Installer
(4,932 Views)
If you are building an executable that uses elements from the DSC module, you will also need the LabVIEW DSC Run-Time System Deployment License. Without this license, DSC-related elements of an executable will not work properly.
Daniel V.
(4,888 Views)
Adding onto that, the license is per PC so hopefully you're not planning to deploy this to a large number of machines.
(4,879 Views)
