labview email.
The application I am developing requires the integration of LabVIEW into a complex .NET WebService, which is responsible for user authorization, authentication and scheduling. Most of the control of the LabVIEW application is managed within the IIS service via VI Server methods and a few VI's loaded during IIS startup. RemotePanels are displayed within the ASPX pages using a user defined ASCX control.
To solve the problem of passing information from an IIS WebServer to the LabView WebServer, I created a CGI VI on the LabVIEW server which parses the parameters issued from the IIS initiated redirect. The CGI then publishes the requested VI after setting the passed parameters.
Message 11 of 31
(3,876 Views)
Dear Mike:
         Could you kindly help to resave your attached vi to version 6.1 of LV ? By the way, do you this Ostrosoft toolkit  have any limit of attachment size? Thanks a lot !
Message 12 of 31
(3,838 Views)
<quote>when i run the lv7.0 example SMTP vi, it always fail. why the SMTP email send vi doesnot ask me to input "user name" and "password"?
</quote>
Because traditionally SMTP did not require login informations. It was usual to allow anyone who knew the SMTP server address to just connect to it and send of whatever he wanted. Only POP3 required login, since there you could retrieve privat information meant to be read only by the targetted individual. Nowadays with Spam attempting to kill traditional email more and more, a lot of SMTP servers have been tightened up and require some sort of login if they are not on a tightly protected subnet themselves.
The login procedure for SMTP is an addition to the original standard, and there are actually more than one way to authenticate with SMTP. Some SMTP servers require you to first login using POP3 account authentification from the same computer before you are allowed to send your messages. Others use an extension to the SMTP protocol and here you have again several levels of security. The lowest is plain password and username which is basically of no real use on a non private network nowadays. Then there are several encryption variants some with challenge response. The LabVIEW SMTP VIs do NOT implement any of those authentification mechanismes.
I have posted some time ago some VIs here in the developer exchange which implement at least the most basic authentification scheme. For the more extensive authentification schemes you do need some specific encryption and hash algorithmes such as are available in the Crypto-G library from http://www.jyestudio.com/visecurity/. For its price this toolkit delivers a real good functionality, but you need to have some basic understanding of cryptography to make good use of it.
Implementing the actual SMTP authentification is still an exercise to do reading the relevant RFCs, but I won't be able to post specific code here.
Rolf Kalbermatter
Message Edited by rolfk on 10-18-2005 05:25 AM
Rolf Kalbermatter  My Blog
Message 13 of 31
(3,835 Views)
Would it be possible to get these two examples on how to sent emails in LABVIEW CONVERTED TO VERSION 7.0. The reason been the version of labview I am using is at 7.0
Message 14 of 31
(3,794 Views)
Would it be possible to get your example of sending an email
in labview converted to version 7.0. The reason been is that the version of labview I am using is 7.0
Message 15 of 31
(3,793 Views)
Here are the two previously posted VIs converted to LV 7.0
I'm working on converting them back to 6.1
Emma R
NIUK & Ireland
Message 16 of 31
(3,774 Views)
Thanks for your help
Message 17 of 31
(3,770 Views)
My company uses an Enterprise anti-virus program that doesn't allow outgoing traffice to port 25 (SMTP)
... unless the port-blocking is temporarily disabled 🙂  (probably need to be a local admin for this VI to work 😉 )
When they give imbeciles handicap-parking, I won't have so far to walk!
Message 18 of 31
(3,763 Views)
Here are both the VIs coverted into LV 6.1
Hope they are helpful
Emma R
NIUK & Ireland
Message 19 of 31
(3,756 Views)
I am getting an error 54 when I run the Email_Alarm.vi and the Email_WithAttachmemt. Has anybody come across this error and if so what was the solution.
Message 20 of 31
(3,754 Views)
