labview event structure
hello
can anyone tell me why the terminal shown by circle 1 at the start of event structure is showing different from the circle 2 at the end of event structure
thanks
(2,818 Views)
Because you configured the terminal to use default values and somewhere you didn't wire the terminals.
Rodéric L
Certified LabVIEW Architect
(2,795 Views)
This is a tunnel that has enabled the option "use default if unwired", this is the default option when working with the event structure.
http://zone.ni.com/reference/en-XX/help/371361G-01/lvscript/conditionaltunnel_use_default_if_unwired...
Ing. Jonathan E. Cruz Ortiz
ENERGÍA PROACTIVA S.A.S
Cel : (+57) 3173669343 - (+57) 3124451894
(2,784 Views)
Hey,
Use Block Diagram Cleanup Diagram, Couldn't understand your problem!!!!
(2,780 Views)
