labview\examples\general\cntrlref.llb Where is that?
Hello everyone,
I was searching something up on key focus from this page,
http://zone.ni.com/reference/en-XX/help/371361H-01/lvprop/ctrl_key_focus/
and to find an example I was referred to that path:  labview\examples\general\cntrlref.llb
However I cannot find that anywhere either on disk or in example finder either. Anyone can help me?
Thank you very much!!
(2,501 Views)
What version of LabVIEW are you using? The help page you linked to is for LabVIEW 2011, but it seems that this example was removed for newer versions of LabVIEW (I do not have it for 2017).
Do you have a specific question regarding the key focus property?
(2,428 Views)
Accepted by topic author rajiv85
That example was removed in LabVIEW 2013. I've attached the example LLB to this post. But I don't know how much help it will be, the only VI in that LLB that uses the Key Focus property is String Property Node.vi, but the use of the property is very simple...a TRUE gives focus to a control, a FALSE removes focus.
(2,407 Views)
