labview excitation voltage
Hello All,
Can Labview, without any external source supply excitation voltage? if yes how much?
(3,648 Views)
You mean, without any hardware????
(3,645 Views)
Yes Devchander.
As I said in my previous message, I am using DC-50LP connector block, PCI-DAQ card and LabVIEW software. Can LabVIEW supply excitation voltage with out any external signal conditioning system? Can I be able to power strain gages with the hardware and software I am using?
Regards
Mekdeng
(3,641 Views)
Hi Mekdeng,
Well, if you are having a AO/Multifunction DAQ card, you can indeed generate an analog output voltage.
plz take a look at any analog output examples shipped with Labview to get an idea on how to go about it.
If you plan to use it as a voltage source with its generated AO characterstics/specs( absolute accuracy, output coupling, output impedence, current drive, stability) i do not foresee any problems.
Since you plan to use it as an excitation for strain gage, check if these AO characterstics suit the strain gage excitation requirements.
Regards
Dev
(3,632 Views)
Mekdeng,
Unfortunately, the analog output on your DAQ card can only source a very small current (~5mA). I would recommend using the 5V output of the card as your excitation. In addition to the voltages on your bridge completion network, I would also read the 5V supply so you know the exact voltage supplied and are able to more accurately calculate the strain.
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
(3,611 Views)
You can find an application note on low cost (US$79) strain measurement
using LabVIEW at the following link
http://www.emant.com/325007.page
"Ryan V" <x@no.email> wrote in message
news:1132697446732-291782@exchange.ni.com...
> Mekdeng,
> strain.
> Hope this helps,
(3,601 Views)
