labview.exe ??
Hi.
How do you create an .exe file from an existing .vi file ??
I want to create exe files that work on a PC without Labview installed...
is that possible ??
Bo Pretzmann
EuroCom inc.
Message 1 of 9
(4,548 Views)
there is a add-on
called
application builder $$$
BTB wrote in message news:iCd96.37$r4.2675@news.get2net.dk...
> Hi.
> is that possible ??
> Bo Pretzmann
> EuroCom inc.
Message 2 of 9
(4,548 Views)
Bo,
there is also something called vi player thats available for free, you can
download it from ni.com. I haven't used it, but I believe it allows people
without labview to run vi's if they download the player. if you want a exe
file though, you do need application builder.
"BTB" wrote:
>Hi.>>How do you create an .exe file from an existing .vi file ??>>I want
to create exe files that work on a PC without Labview installed...>>is that
possible ??>>Bo Pretzmann>EuroCom inc.>>
Message 3 of 9
(4,548 Views)
LabVIEW Player has some limitations that must be known if you plan to use
it. Here is a notice I received from NI about LV Player. You can look at the
following page for more information about it:
http://www.ni.com/labview/lv_player2.htm
Hope that helps.
Roberto
The communication abilities of LabVIEW Player VIs are limited to file I/O
and DataSocket client operations
(publishing and subscribing, but no server capabilities). All data needs to
be simulated because data acquisition,
VISA, GPIB, and serial I/O functions are not supported in LabVIEW Player
VIs. Similarly, the LabVIEW Player will
not invoke ActiveX Automatio
n, CINs, or DLLs and shared libraries.
"patrick sincebaugh" ha scritto nel
messaggio news:3a659fcc@newsgroups.ni.com...
> Bo,
people
exe
that
Message 4 of 9
(4,548 Views)
Hi Bo,
What you want to do is exactly possible by Application builder,
able to be loaded by project(main menu)>>create application.
If you cannot see "create application" on the menu, you need to
install Application builder for your purpose. Hope to help.
Tom
BTB wrote:
> Hi.
> is that possible ??
> Bo Pretzmann
> EuroCom inc.
Message 5 of 9
(4,548 Views)
Thanks to you two for your help..
I can now make .exe files from vi's.... Its great...
And they run on win 95/98 computers without Labview installed...
But i still have 1 question...
When creating an application is it then possible to select system ? In my
case Windows3.1 or 3.11
Thank again for your help.
Bo D. Pretzmann
ECI.
Message 6 of 9
(4,548 Views)
As best as I can remember, LabVIEW support for Windows 3.x was dropped when
version 5 came out. Even when it was supported, I think you had to have a
separate app builder.
"BTB" wrote:
>Thanks to you two for your help..>>I can now make .exe files from vi's....
Its great...>>And they run on win 95/98 computers without Labview installed...>>But
i still have 1 question...>>When creating an application is it then possible
to select system ? In my>case Windows3.1 or 3.11>>>Thank again for your help.>>Bo
D. Pretzmann>ECI.>>
Message 7 of 9
(4,548 Views)
Bo,
I have not experienced in Win3.1 or 3.11 yet, but they
are involved in capable operating systems as description
in "os.dat" file, at APPLIB\installs\RunTime. You need
not worry about avalilability I think.
Tom
> Bo D. Pretzmann
> ECI.
Message 8 of 9
(4,548 Views)
[posted and mailed]
Hi@A.be (BTB) wrote in :
Depends on your version of LabVIEW. Versions 2.1 through to 4 came in
flavours to run under Win3.x. Unfortunately versions 5 or greater do not
support EXE's that will work under earlier versions of windows (such as
3.x).
Alexander C. Le Dain, PhD
ICON Technologies Pty Ltd
http://www.icon-tech.com.au
* The LabVIEW FAQ ht
tp://www.icon-tech.com.au/thelabviewfaq.html *
Message 9 of 9
(4,547 Views)
