labview floating point and decimal differentiation
Hi, Can i know what modification can I make to let the display differentiate between floating point and decimal. For example, when I input 2+2. I would like the output of 4 instead of 4.000. And when the input is 2.2 + 2.2, how to get the output of 4.4 instead of 4.4000. And also would like to have keep 4 decimal for trigonometry function.
Message 1 of 35
(4,282 Views)
Hi tan,
set the display format of your indicator to "hide trailing zeros"…
Spoiler
Something like %#.4g would help…
Message 2 of 35
(4,280 Views)
But the indicator in the VI is string type. There is no option to set hiding trailing zero for that string indicator.
Message 3 of 35
(4,232 Views)
Accepted by topic author tan99323
Hi tan,
In this case you are doing the NumToString conversion before displaying the result in an indicator.
Use FormatIntoString with the format string I mentioned in the other message…
(Now it would help to provide your VIs for older LabVIEW versions like my LV2017.)
Message 4 of 35
(4,219 Views)
In case to enable insert numpad input while the VI is running, what modification can I make ? So user can input date from numpad instead of press those boolean button.
Message 5 of 35
(4,153 Views)
Hi tan,
You need to catch those keypress events…
(Btw. you should use the ValueChange instead of MouseDown events.)
Message 6 of 35
(4,144 Views)
I have tried to change the event for 0-9 to value change , but still unable to input from keypad. Which element should i add to the VI ?
Message 7 of 35
(4,139 Views)
Hi tan,
you need to look for keypress events...
Message 8 of 35
(4,128 Views)
So, I need to duplicate the 0-9 mousedown event and change to key down on the new duplicated event ?
Message 9 of 35
(4,125 Views)
Hi tan,
no need to duplicate anything.
Just catch keydown events of your VI…
Message 10 of 35
(4,115 Views)
