labview fpga with nexys 2
hi my friends I want to know I can use labview FPGA with nexys 2 and there are some device about this FPGA (nexys 2) because we have this circuit board and we want to do the project with labview you can found some information about nexys 2 in this file and thank you for your help
(3,360 Views)
As this forum thread states, LabVIEW FPGA is only for the SPARTAN-3E XUP Starter Board and NI Reconfigurable I/O devices. Even though the nexys 2 is based from the Spartan 3E, we can’t be sure that the driver that we release for the Spartan 3E starter board works for the nexys 2.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(3,328 Views)
thank you for your help so I dont found device for nexy 2 because we have this circuit but I dont know than I use device of spatan 3E for nexys 2
(3,320 Views)
I'm sorry, but I don't understand. In order to use LabVIEW FPGA, you would need to get the SPARTAN-3E XUP Starter Board. This is the best solution for academic pursposes. Other cards are most likely not going to work with LabVIEW FPGA.
Daniel REDS
RF Systems Engineer
Help us grow.
(3,311 Views)
The main issue is with the actual configuration of the different boards, namely which peripheral devices (switches, LEDs, flash, etc.) are on the boards and how they are connected to the same FPGA part. So, no, different boards that have different IO hooked up to different pins are not going to work properly with the Spartan3E Starter board driver.
(3,277 Views)
