labview fpga
When I compile a labview fpga VI, (my version of labview fpga is 2014), I get the compilation error Xilinx 10.1 tools not found.
But for labview 2014, Xilinx 14.7 version is the compatible one and that i have installed. But still it asks for Xilinx version 10.1. I tried it both with CompactRIO configured and also a vi without hardware.Same thing repeated each time.
What can be problem? Please help me.
Lahari
(4,321 Views)
Accepted by topic author Lahari
What FPGA target are you using? I think for Virtex 2 targets the Xilinx 10.1 tools are used.
(4,299 Views)
Thank You. I checked it now, I need to install 10.1 versio now.
But then wont there be a conflict between the two versions? or should I uninstall the 14.7 version???
(4,291 Views)
No need to uninstall, you can have both versions in parallel. LabVIEW will pick the Xilinx compiler suited for the FPGA target.
(4,282 Views)
Yes many versions of Xilinx can be installed at once.  In the future use a more descriptive title.
  • Have a useful title.  The title of your question should never be "labview" for "fpga".  Your title should also not be a paragraph.  It should be a quick summary of the topics your post is going to discuss.
Source
(4,260 Views)
Okay, i future I will come up with better descriptive titles.
Thank You and apologies for the now inconvenience.
(4,241 Views)
 Thanks a lot.
(4,240 Views)
