labview freezes during FOR loop
Alright, I just updated Labview. It seems to help a bit, but it still freezes during execution.
This is a version of the VI which only runs the servos. I've tried debugging the code with this, but still cannot make any progress period.
Message 11 of 16
(787 Views)
You might also want to masscompile the driver. Your toplevel VI is in LabVIEW 2011 and the driver is still in 8.0.
Message 12 of 16
(782 Views)
Tried that. The VI still freezes.
Message 13 of 16
(748 Views)
Did you try to get support from whoever made that driver?
Message 14 of 16
(744 Views)
Tried that. Velmex suggested increasing the wait time. I did that, and Labview still freezes.
I've heard Velmex makes terrible labview drivers. I'd make a better one, but I don't know how to.
Message 15 of 16
(719 Views)
While working for a previous employer, I used the Velmex motors and VXM controller. After one look at their driver (and the fact that I was running on a Mac), I wrote a controller which used the RS-232 interface.  The VXM users manual had a complete list of the available commands. No DLLs. No weird conpanes. No undocumented functions. I no longer have access to that code and it probably only implemented a small subset of the commands because we had a fairly simple project (mechanically). Although we did want it to do something the Velmex applications people said it could not do. We did it anyway.
I suggest that you could do the same thing. If you only need to implement a few commands (as it appears that you might), then this should not be too difficult. Writing and testing the code to implement every command is a much more complex task.
Lynn
Message 16 of 16
(675 Views)
