labview frequency cutoff issue
I have an issue with labview where my .wav file that i play for my VI gets an error about frequency cutoff. I am very confident my schematic is fine but i dont know what is the problem?
Attached is my .vi and the .wav file. when you run the program you will get an error like in my screen shot. the cutoff frequency is between 10hz to 4000.
even with the error if u push continue you will get a play back, "That doctorine has been accepted by many, but has it produced good results" Please help.
(2,871 Views)
Do your cutoff frequency values meet the requirements specified in the error message?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,839 Views)
yes, my cut off frequency given in .vi file is 10hz to 4khz.
(2,802 Views)
So f_low is 10Hz, and 4kHz is f_high, right? what is the sample rate (fs)?
Mike...
LabVIEW Champion
(2,791 Views)
