labview help (clusters)
I am a new labview user and I have a basic question I hope you call can help me with. I have a cluster control whose elements I need to update by reading values from a config file. In addition, have to be able to override the values in the elements manually from the front panel. All the examples I have read suggest creating a second cluster indicator, but I want to have only one cluster whose elements I need to update.
Thanks in advance for the help.
(2,581 Views)
You can use a Local Variable to update your cluster control.  I would just have a button for "Load" and another for "Save".  I think it is obvious what should be done when those buttons are pressed.
(2,573 Views)
A property node would also make this possible.
Of course there are libraries that read\write ini files and reading\writing control values in standard functionality (except for NI's lib 😑).
(2,517 Views)
If you are new to LabVIEW you should probably learn the basics about local variables, and File IO.  But there is a pretty neat set of functions in OpenG that can save a panel to an INI file, and load a panel from an INI file.  OpenG needs to be installed separately through VI Package manager, and on the Variant Configuration File palette there is the Read Panel From INI, and Write Panel to INI.  You need to open a reference to a file first, and close at the end.
But again I'd suggest you try to understand the basics first.
(2,493 Views)
Open G is great.
Also Hooovahh 😉has some great tools as well https://www.vipm.io/publisher/hooovahh/
Here is where the Open G cluster to .ini stuff is located on the palette.
Dan Shangraw, P.E.
(2,483 Views)
Thank you all for your valuable suggestions. I will try to strengthen basic labview skills and try the things you all are talking about. Thanks again!
(2,469 Views)
