labview help
How to correct the following error. I want to connect a waveform Graph to the output as shown, but i got an eror. is there a way to convert to the required data type?. I used merge signal and then connected the graph but nothing shows, what s the problem
(3,062 Views)
Switch over to a Waveform Chart. I don't think that you want to plot only one data point...
Regards, Jens
Kudos are welcome...
(3,052 Views)
Hi Shivik89,
I also agree with the use of a chart over a graph for your situation.
- A graph is sort of an end of process dump of information to display a whole dataset as a complete visual graphic.
- A chart will plot in real time as the information is inputted to it. Generally you want to use a chart if it is inside of a structure loop.
This will be really helpful in explaining further: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9zsSAC&l=en-US
I can also see you are using a bundle function to get both your plots and therefore using a cluster of what appears to be both numeric data types?
If this does not work for you are you able to use a 2-dimensional array? This will be successful for you I believe.
Kindest Regards,
Matthew
(3,004 Views)
