labview installation
I just download LabVIEW from NI. while installation, I get the following error when I run the autorun.exe.
Windows cannot find 'C:\Program Files\National Instruments\NI Package Manager\NIPackageManager.exe'. Make sure you typed the name correctly, and then try again.
How should I resolve this issue?
(2,214 Views)
Try manually installing NIPM from here.
EDIT:
or try finding it, it might just be installed in the wrong folder.
(2,212 Views)
sir,after click on the link one tab shown as"This Installer required Windows 10 64-bit (version 1507) or newer"
(2,184 Views)
So give us more information:
Which LabVIEW version would you like to install?
What's your Windows version?
Kudos are welcome...
(2,180 Views)
