labview intallation unknown error
I am trying to install Labview 2013 developer suite on my PXIe- 8135 embedded controller with Window 7 64 bit OS. The installation doesn't start as a dialogue box appear saying Unkonw Error and there is no detail about that error.
Can someone tell me what the real issue is?
(5,652 Views)
What medium are you using for the installation?  Have you tried installing the software on a "regular" PC?  Does it give you the same error, or does it appear to begin the installation (when on a regular PC)?
(5,643 Views)
I did install on my PC that has window 7 64 bit OS, it works fine on that. But on this PXIe sytem it never get to install. I get the follwoing warning as well. I ignore it and press next. But, the then an error mesaage appears that say unknown error.
Notification Summary   Critical Warnings: 1
Critical Warning
Duplicating Graph Controls in NI LabWindows/CVI 2009 May Cause Memory Corruption
A patch is available for NI LabWindows/CVI 2009 that fixes a graph control duplication bug. The patch is recommended for all NI LabWindows/CVI 2009 installations. Refer to the URL listed below for more details and to download the patch. Finish this installation, and then install the patch. To download the updated version and obtain more information, copy and paste the following URL into your browser or visit ni.com/info and enter the Info Code: NotificationNICVI2009graph.
Link: http://digital.ni.com/express.nsf/bycode/NotificationNICVI2009graph
(5,638 Views)
It sounds like you have multiple versions of LabVIEW on your PXIe controller (the error message mentions the LabWindows 2009 Run Time Engine).  NI has identified this as a known bug that should be patched -- install the patch, and then see if you still have problems.
It is not entirely obvious to me why you would install a LabVIEW Development System on a PXIe controller, anyway.  Yes, it does have an Intel processor and can run Windows, but it is not an ideal development environment (limited monitor options, limited peripherals, etc.).  [I should mention that I have no experience with LabWindows -- I tend to use my PXI controller with LabVIEW RT, and do not have Windows installed on it, only the Real-Time OS].
You didn't answer the question of the Distribution Medium.  Are you installing from a multi-DVD distribution, are you downloading individual modules and installing from them one at a time, are you using an external DVD drive, etc.  Knowing more might give us a clue to what is going on ...
(5,618 Views)
I am using the set of DVD provided by NI. I even tried to install the patch. During the installation I have a pop up windows saying unknown error. It happens during the patch installation as well. The system seems to not accepting installation of any of the NI's softwares
(5,607 Views)
i have the same error here. need help
i download on a regular PC. windows 7 32bits
after i downloaded the file. the installation wouldt start and a dialog box pops out saying an unknow error.
(5,516 Views)
Hi Mr_yandao,
If you click on the Details button, do you get more information about the error? Have you tried disabling the anti-virus?
(5,478 Views)
