labview interface arduino dc motor control with limit swtiches.
Hy Everyone
I have a question. My project is  for 4 level elevator system. I want to stop the lift at every level with the use of limit switches. Once the motor (dc) starts rotating and say for exaple i want to go from ground to level 2 then when it reaches to level2, the limit switch should sense it and stop the motor at level 2.
I will be using labview and arduino mega 2560.
Can this be done?
regards
Kunal
(2,991 Views)
I've never worked with limit switches before, but yes it looks like you can have a different limit switch for each floor and set up states where if you want to go to level two it ignores the signal from the limit switch at level one and stops when the limit switch at level 2 is triggered. Sounds like you've got it figured out.
Casey B.
(2,932 Views)
