labview interfacing with labjack U3-HV
Hi, I am new to labview. I am doing a project on motor control. Here I have to find the following parameters of motor using Labview 7.1 version along with Labjack (U3-HV) : 1) Torque 2) Voltage 3) Current 4) Speed I don’t know how to write a code for these parameters in labview and I didn’t find any blocks like IC’s, chips, motors in control and function palette. Plz guide me for the same and post all your suggestions here. Thank you.
(5,330 Views)
Hi labview, The IC’s, chips, motors etc: are not available in function or control palletes. For getting started with labjack,please see here http://www.labjack.com/forums/index.php?showtopic=84 http://www.labjack.com/lju12datarates.php Hope this helps.
Thanks as kudos only:)
(5,318 Views)
Accepted by topic author ni_labview1
That is a good link to get started using the U12 with LabVIEW.  For the U3, the following are a couple good links:
http://labjack.com/support/u3
http://labjack.com/support/ud/examples/labview
See the following topic on the LabJack forums:
http://forums.labjack.com/index.php?showtopic=5894
(5,293 Views)
