labview isn't responding on windows 8
I'm pretty sure the environment was set to labview but when I tried to make sure and change it to labview that window went unresponsive.
Message 11 of 13
(608 Views)
Wait, when you start it up it doesn't show up with the FRC tutorials, help, projects, etc?  Is it possible to take a screenshot of your splash?  If you installed all of the FRC software, you should see the FRC environment rather than LabVIEW.  LabVIEW will be a rectangular shape with options to create a new project in the left and a history of projects/VIs you've worked with on the right.  Which of these are you seeing?
Message 12 of 13
(594 Views)
The frc stuff shows up but when I went to change the environment the only option was labview.
Message 13 of 13
(587 Views)
