labview keithley 2400
buenas tardes compañeros son nuevo en labview y tengo que realizar un vi con el instrumento  keithley 2400  un barrido y graficarlo... alguna idea para empezarlo? o alguien que me puede ayudar y ponernos en contacto..gracias
(4,189 Views)
Hi promotor,
please don't get into the habit of spamming forum members with private messages. Especially when you send the same message content as you have written here in your thread!
Also this is an English speaking forum, so you should post your questions in English. Or use the Spanish regional community!
good afternoon companions are new to labview and I have to perform a scan with the keithley 2400 instrument and scan it ... any idea to start it? or someone who can help me and get in touch ... thanks
To start you should take the "Training resources" offered in the header of the LabVIEW board to learn LabVIEW basics.
Then you should learn about the IDNet (Instrument Driver Network) at ni.com and use the provided K2400 driver offered there…
(4,152 Views)
hello good morning, I made this VI to do sweeps  with the keithley 2400 team, could you help me is that I try and it gives me nothing and i don't know how to set current limit, thank you very much
(4,137 Views)
Hi promotor,
it gives me nothing
You get "nothing" even though you are reading two values from your device?
Do you get (atleast) an error?
Read the manual of your device to learn how to set current limit(s)…
Is there no VI in the K2400 driver which allows setting that parameter?
(4,092 Views)
HELLO I'M LOOKING FOR THESE VI THAT ARE FROM KEITHLEY 24XX BUT THEY ARE OLD BECAUSE I ALREADY INSTALL THE NEW AND FOLLOW ME MAKING MISTAKE
THE SUBPROGRAMS ARE CALLED  KEITHLEY 24XX DCV SOURCE CONFIG.VI  ...... AND ... KEITHLEY 24XX DCI MEASURE CONFIG.VI
(4,087 Views)
I MAKE MEASUREMENTS AND ALWAYS GIVE ME A STRAIGHT IN THE GRAPHICS AND THE TEAM APPEARS VALUES THAT DO NOT, SOME SUGGESTION
(4,071 Views)
Hi promotor,
No need to cry! (Maybe your keyboard is broken?)
I suggest you debug your VI to find the reason of those "straight"…
(4,065 Views)
