labview measurement file saves only one second of data
I am acquiring data using a DAQ assistant( 1000sampling rate, 1000samples per second, multiple samples). It is writing data to a LVM file. Both of these are in while loop. I have acquired data for about 10 seconds. I could see the data as it was beeing acquired.
However when I use the Read LVM express vi and I create a graphical indicator to view the 10 seconds of data, I can only see 1 second.
How can i view/save all the 10 seconds of data . ( viewing graphically is important for me.)
thanks
Shubha
(2,655 Views)
Hi Shuba,
it sounds, as if you forgot to "enable indexing".
Rightclick on tunnel @ while loop and change this property.
Regards
Werner
(2,655 Views)
I'm assuming that your write options are set to append with one header per segment. To read the file, you need to place the read in a loop and exit the loop when the EOF output is true.
Justin
(2,655 Views)
