labview menu
Hi all
  I want insert sub menu vi in other VI,why not appearance in VI as below.
as sub vi insert other VI as below
(3,565 Views)
Hi sageliuliu,
When you put your code in a subVI, Current VI's Menubar no longer returns a reference to the main VI menu.  Instead, it returns a reference to the subVI menu!  You need to leave Current VI's Menubar in your main VI and pass the reference as an input to the subVI.
PsyenceFact
(3,541 Views)
Hi PsyenceFact
    Thanks for your reply,I don't know how to setup with that code and upload it,please help me point out,thanks!!
(3,454 Views)
Accepted by topic author Sam.Huang
I'm still running LV2015 so can't open your VIs.  No matter, here's a little example that shows how it's done.  Run Submenu example 1.vi.  In this, the menu reference is obtained and passed to Submenu example 2.vi.  All the menu setup is done there.
I've also included an event structure to catch the user menu selections.  All it does is check whether the menu tag contains the string "Sub" and, if so, toggle the checkmark.
Hope this is useful.
PsyenceFact
(3,444 Views)
Hi PsyenceFact,
   It's work,thanks for your help.
(3,438 Views)
No problem!  Glad you got it sorted out.
(3,433 Views)
