labview modbus slave tcp/ip ability to handle multiple master?
I have to comunicate my computer (server pc), in slave tcp/ip modbus mode, with differents master in diferentes subnets, can i use a labview modbus library for this? labview modbus slave ability to handle multiple masters? I will use a router to subnetting a masters devices.
Any advice would be appreciated!
César
Lv 8,6
Win Server 2003
(3,029 Views)
Hello Cemach,
I don't see any problems in implementing this using NI ModBus Library. You might need to implement some additional code to manage all the data traffic on the network (Where it's coming from and going to).
You can download the newest version of the MODBUS Library here.
Also, you can post your detailed doubts in the NI LabVIEW Modbus API Discussion.
Best Regards.
Felipe Flores
Technical Support Engineer
(2,871 Views)
