labview modbus
I am new to LabView. I have a development PC in which I have labview 8.5 with activated DSC module.
I am wondering if I can generate an application that can be run on another PC and:
  • reads (for example) address 409017 of a modbus server with IP=192.168.1.140
  • log this data on database
  • shows historical data on a chart
How? Whould anyone explain a step-by-step approach?
I should say that I have worked on the project. Here, I want to know if I am on the right road or not.
Thank You
(4,638 Views)
Are you planning to install LV on that machine?  If not, you'd need to purchase a runtime license for dsc
(4,602 Views)
I want to run the application on another PC that has not LabView installed.
So, how should I do this?
(4,597 Views)
For LabVIEW You can get a Free Run Time Licence or you can Create a Installer from the Developemnet System. But for DSC Module you you need to get a runtime Licence
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,568 Views)
(4,545 Views)
