labview nxg 2.1runtime install error(MD5check error)
(3,318 Views)
Can you enable the MSI and cURL logs as is shown in this KB, and then try and re-run the installation? Once you've done that, can you send me the Package Manager Logs directory (%localAppData%\National Instruments\NI Package Manager\Logs)? Feel free to direct message with those logs if that would work better for you.
Brandon Grey
Certified LabVIEW Architect
(3,282 Views)
Accepted by topic author Magicore
I have followed the steps,There is logs in the attachment。
(3,272 Views)
