labview pda- the suitable pda for this application
Hi , I am trying to develop an application for Pocket PC. The program samples data from 4 channels using the NI CF- 6004, at 50Hz, and insert the data to array called "force". For each sample, the program averages the data from the 4 channels, and then do calculation and present 3 outputs (see the attached VI, made at labview 8 pda module for pocket pc ). The reading, analyzing and presenting of the data must be in real time.
I am having difficult in choosing the proper hardware of the pocket PC that will do this task the bets way, meaning:
1. which company ( HP, or others ) ?
2. speed of the processor ?
3. memory
ect.
If anyone have any ideas about this subject I will appreciate your thought.
(2,612 Views)
The only requirements are the following: 1) you have a PDA with a CompactFlash Type II slot, 2) it is running PocketPC 2003.  As long as the PDA meets these requirements, it will be able to run your application.  Beyond that, it is up to you to determine how much performance you want from the processor and memory.
You may want to take a look at CompactFlash Data Acquisition Frequently Asked Questions for more information.
(2,589 Views)
