labview printing
i came up against another question to which i had no idea what the answer was?
 it said
 in labview you may print to all of the following, Except
1. printer 2.HTML 3.plain text  4.all of the other are possible printing options
please help
(4,059 Views)
This one you can look up yourself.
Go to the File menu then pick Print.  Go through a couple dialog boxes until you get to the one that shows you what the printing choices are.
(4,045 Views)
What options do you actually see when you try File>Print?
(4,044 Views)
If you can't run labview (maybe you're away from work for the weekend), it probably wouldn't be a bad idea to mention it.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(4,022 Views)
well i feel embarrased. i should have looked into the file>>print menu before asking. thankyou for being patient
(3,999 Views)
