labview project does not run on different computer
I have some problems with a lvproj file containing an application. The application used to work with as long as I had all subvis inside a llb file. With the very same VIs I now created a lvproj file on Labview 8.6. I can successfully load and run the program on 2 windows machines, but I get very odd error messages on a third Windows machine.
The error seems to be related to a mathscript node I'm using but I don't understand why this is a problem. I get an error code -90001 "Error in function path at line 1. A problem occured  in a subvi call".
As said before, this works perfectly find with the old llb file, but not with the lvproj file. How can I fix this?
I tried the obvious things like rebooting the computer & restarting Labview, but no I had no success so far to get this running.
Message Edited by kandreas on 01-02-2009 08:30 PM
(2,995 Views)
Hi Kandreas,
Thanks for the post and I hope your well today.
Sorry for stating the obvious first off - but clearly the three computers are not the same.
You could run a MAX System Report to see what differences there are...
Let me know what you think,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,929 Views)
